SOLD Decided to sell up If anyone is interested let me know obviously the price is negotiable https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/332995768601 cheers Si
Thanks mate but some webuyanybike type company is coming to have a look on Wednesday at £3500 so hopefully she will go then. The only sticking point is they said the steering lock must work (which it does) however I have a UK Race steering stop on there so I cant actually show them it does unless I remove it.
Mileage foibles aside, it looks like you've put a pretty decent price on her. Are you going to put the monies to something shiny and new? GLWTS
Hmmmm yep but its an Adventure bike. I fancy heading off into Europe this year and for the amount I used the Daytona last year (low side apart) it really doesn't get much use. The same will probably happen with the adventure bike but who knows
Forgot to add it to the advert but the bike also has a K Tech 20mm SSK Fork Piston Kit in the front forks as well. Its a decent bike chaps don't let the fact its had a lowside put you off. I replaced the fairings, had the tank repaired and repainted to a very high standard, new rear brake lever and new clipons. Arrow Exhaust Matris over the tank steering damper K Tech SSK Front Fork Piston Kit Forks serviced early last year with under 800 miles since Pirelli Supercorsa SC2 rear and SC1 front UK Race steering stop Dyno fuelling set up at T3 Racing Brembo 19RCS Master Cylinder
