Hi I'm looking to get a set of triumph frame protectors but the instructions say to remove the cockpit infill panels which I don't want to do as I've got the carbon ones - do i need to remove them? Also, is it necessary to completely remove the fairings when fitting them? Thanks
I fitted a set of the R&G aero ones to my 14 Daytona without taking the fairings off. I remember I had to loosen off bits of the fairings tho.
Yeah you will need side fairings off completely. Carbon infills come out pretty easily. Just slide up and back .
Yes I know I have to remove the cockpit infill panels but the triumph kit comes with new ones to replace them, but I want to keep my carbon infill panels - can I still fit the frame protectors with replacing the carbon infill panels?
I think you may be getting confused about what the instructions are calling infill panels, the ones on the top that fit up behind the headlights don't need to be replaced, the ones in the instructions that attach to the side fairing will need replacing to allow space for the frame protection, I've never seen those in carbon though.
