Any advice
Discussion in 'General' started by al2930, Sep 23, 2018.
  1. al2930
    al2930
    Hi all,
    See the plastic triangular thingy under the guard - mine has come lose and is rattling a little at low speeds. Is this an essential part that I could do with replacing or fixing, or can I just simply take it off.
    Any help is much appreciated. Cheers. 62CC24AB-347B-4FBC-894B-AFFADBB01FE2.jpeg 8532EB09-D337-4C59-8433-E31F25139E02.jpeg
  2. Sulaco161
    Sulaco161
    122
    It locates into the fairing panel, with rubber gromets these quite often get pushed out when replacing the triangular piece, check to see if they are still there, they might just be displaced, not missing.
  3. Sulaco161
    Sulaco161
    122
  4. al2930
    al2930
    Thanks very much.
    I can’t feel the gromets and fear the right side one has fallen out. I’ll see how easy it is to replace the part. Cheers.
  5. Sulaco161
    Sulaco161
    122
    It's a simple job, you should be able to do it by removing all the screws on the underside of the fairings, and the bottom 2 bolts on both sides, this should give you enough wiggle room to do what you need, or you could just remove the fairings. The gromet might not be missing just pushed back into it's holder. I usually put a small amount of grease/washing up liquid, whatever I have to hand to help the V piece slip into the gromets easier.
  6. StMarks
    793
    Iirc there is also the bottom front scrivit (No 7 on above drawing) that goes through the overlapping lugs on the bottom of the two side panels, and also through a lug on the bottom of that V-piece. It keeps the whole assembly rigid & secure.
    Hth
  7. Have a look at what your missing or if any of the lugs are broke.
    I have some of these triangles & fixings You can have for the price of postage.
  8. al2930
    al2930
    Really appreciate all your comments. Been out today riding on the roads of Northumberland so I’ll have a look later through the week and see what parts if any I might need.
    Cheers for this
  9. al2930
    al2930
    I’ll let you know. Thanks mate
  10. Sulaco161
    Sulaco161
    122
    I did this to mine while I had it removed: Photo0036.jpg
    A bit of mesh a few small holes and some lock wire, works a treat keeps a lot of crap from going in.
  11. al2930
    al2930
    Good idea. Am gonna do the same. Looks pretty simple. It’ll have to be for me to sort it!!
  12. al2930
    al2930
    Hi mate. Is it possible to take you up on your kind offer please?
    I could do with 2 rubber grommets for the above part.
  13. On the case for you tomoz buddy
  14. al2930
    al2930
    Thanks so much pal. Let me know how to get some cash to you when you’re ready.
  15. al2930
    al2930
    Hey bud. Any luck yet? Ta
  16. al2930
    al2930
    Hi mate. Just wondering if you managed to find any rubber grommets at all?
  17. If Lenny cant find any sure I have some fot tje cost of a large letter.
  18. al2930
    al2930
    Cheers mate.
  19. Did you get these or still want them.
    Been having issues with the App on my phone.
    Just send your address if you still need them.
  20. al2930
    al2930
    Thanks mate. I'll send a SAE to you later today or tomorrow. Bike's been in a service and then put in garage so forgot about it!!!. Really appreciate your help
