Daytona 2013+ headlight mod
Discussion in 'General' started by Gremlin, Jul 24, 2020.
  1. Gremlin
    Gremlin
    26
    Hi,
    Has anyone modded their lights so that both headlights come on, on dipped beam, rather than just the one?
    Thx.
  2. Gremlin
    Gremlin
    26
  3. StephenP
    187
    Did the KT headlight swap on my 12 model, should be the same as the 13+ I guess[​IMG]
  4. Gremlin
    Gremlin
    26
    Is it a straightforward swap? I'm guessing it passes the MOT?
  5. StephenP
    187
    Hiding the wires is the tricky bit. Will let you know if it passes, got a friendly mot places so it should do
  6. Many years ago I modded my road 675 with a kit from here -
    Clever stuff as it provided a lower voltage to the high beam but gave full power when high beam was used.
  7. White
    White
    265
    27
    Was it straightforward to fit this ?
  8. Very easy, click the above link as there are instructions too.
  9. Fitted mine many years ago can set on different brightness mine also has light sensor which turns off high beam at night as not too blind oncoming drivers I put tape over sensor when it’s mot time
  10. Gremlin
    Gremlin
    26
    This looks ideal, but there's no link to buy and no price on the website?
  11. Contact form or facebook perhaps?
  12. D675hogg
    D675hogg
    144
    14
    I bought this kit to try it. Doesn’t work on the 2013+ models
  13. That’s a surprise as the headlight plugs are the same, where does it plug in?
  14. D675hogg
    D675hogg
    144
    14
    Plug are the same but the older model uses a bulb than can switch between high and low beam. H9 / H7 twin headlight arrangement.
    The new bikes just have one bulb on each side that is either on or off.
