Daytona 675 ecu swap
Discussion in 'General' started by chris cook, Apr 30, 2017.
  1. chris cook
    chris cook
    hi guys just wondering what is involved when changing an ecu over? is it a simple swap and load map or do they keys need reprogrammed etc??
    bike is a 2006
    Thanks in advance
    Chris
  2. towser
    towser
    818
    34
    A 2006 should be plug and play if its got the right map in it. Certainly no keys needed.
  3. chris cook
    chris cook
    I was going to put another ecu in and load the current map on my ecu at the moment? I see one on ebay for 45 bucks so might give it a go.
  4. Make a note of the saved map on your bike ecu.
    Unplug ecu, replace it with spare.
    9/10 will have an altered basic map.
    Then you can adjust the spare ecu map, then see if just disabling one thing at a time allows the bike to run
  5. chris cook
    chris cook
    Thanks again m8,
    tried everything mentioned on the other post to get her going but no go... so either a wire is grounding or the ecu is kaput... place your bets here....
  6. chris cook
    chris cook
    Anyone know what the letter at the top is for on the ecu? Every ecu i have seen advertised is showing a different letter?
  7. Check the 'new' ECU is in the same VIN range using the list on tuneECU. It will also give you the current version of the required map.
  8. chris cook
    chris cook
    Thanks man. What list is that? On pc version?
    Ahh u mean in the website yeah good idea m8 thanks
  9. Where the tune lists are.
    Each tune is listed for a given VIN range. Use that as a guide.
  10. chris cook
    chris cook
    Thanks again. Any idea what the letter is? Bit worried ill shell out and it wont work the cheapest for my year is just under 100quid
  11. Ato
    Ato
    19
    Hi I know I am jumping on an old thread but i did a swap where I replaced the wiring harness, sub harness, ecu, guages. But the bike isnt starting. The only issue I run into was the crank shaft sensor, the new one from the subharness I got was a two pin/wire while the old was a thee pin/wire. I tried to splice the 2 wire to the 3 wire leaving one out but the bike isnt starting, ignition isnt even turning and fuel pump isnt priming. What am I missing.
  12. StMarks
    833
    I wasn't aware of any CPS that had 3 wires.?
    What harness are you putting onto what bike please Ato.?
    There is a thread on here about the Crank Position Sensor, may be worth you taking a look at it.?
  13. Ato
    Ato
    19
    double post
  14. Ato
    Ato
    19
    Hi thanks I will take a look at that thread about the crank position sensor. So I am putting a 2013 street triple r 675 abs wiring components on. I am attaching what the sub wiring harness looks like for the 2013-16 (red) and for what was on the bike (white). The bike I believe is a 2012 street triple r 675 abs, however, the prior owner who I have no clue what he did to the bike says its a 2014. But in short it looks like the wiring that was on there was a hackjob to get the bike to run for track or something View attachment 50217 View attachment 50218 and I am trying to rewire back to stock.
  15. Ato
    Ato
    19
    sorry I actually i uploaded the wrong picture. The sensor in red is what is on the engine of the bike. So it has a three pin connector. The one i bought is actually from a 2013 speed triple R (ABS) 1050 which has a 2 pin connector. This two pin connector fits into the harness I bought. So i thought maybe I could splice and replace the old 3 pin with the new 2 pin head since thats the remaining piece. because basically the end head of the 2 pin could not fit onto the engine
  16. Bigmac
    Bigmac
    4,879
    294
    That is the gear position sensor bud
    Not the cps
  17. Ato
    Ato
    19
    Hi can you please educate me some more if this is correct, because every search ive done on google or even the repair manual for the crankshaft sensor has brought up these images up. Can you post a picture of what the CPS looks like then.
  18. StMarks
    833
  19. Ato
    Ato
    19
