Daytona race parts & Spares for sale
Discussion in 'For Sale' started by Bigmac, Jul 5, 2020.
  1. Bigmac
    Bigmac
    300
    Spare & parts for sale
    This list will grow gradually as I’m having a big clear out.
    All parts are 06-12
    08 frame with v5 £700 collected
    2012 R frame with v5 £950 collected
    Pitbull steering damper £225
    Ktech DDS pro rear shock £650
    Ktech RDS forks £650
    06-08 forks spares & repair stanchions pitted £100
    Gb sharks fin £20
    Unknown make of clip ons £50
    T3 racing sharks fin £20
    Radiator fan £15 x 2
    Starter motor £60 x 2
    Spare radiator (solid but seen better days) £50 x 2
    Good condition radiator £90
    Tank £90
    Battery tray with borealis rain light £65
    Clocks 09-12 (gravel rash and lugs broke) £125
    Clocks 06-08 (one lug broke) £125
    Stock shock £50
    Air scoop/duct £90
    Radiator guard £20
    Rear disc £10
    Hose kit £10 x 2
    Fairing brackets £5
    MWR air filter £45
    Air box £15
    Fuel pump £60
    Rear mud guard £15
    Throttle bodies with manual idle £50
    Manual idle adjuster £20
    Rear brake line clear £10
    Engine mount bolts £10
    Under yoke lock stock UKRS £10
    Shorter ally gear actuator £10
    Brake fluid res front £5
    Brake fluid res rear £5
    Generator & CPS (in case with gasket) £90
    Radiator cap £5
    Time pulse engine case £5
    Carbon tank protectors (seen a bit of action) £20
    Light weight rear disc £20
    2011 loom and ecu (made keyless, needs some cleaning up but came from a working bike) £150
    Street triple loom (unknown year) £50
    Every daytona sensor going £??
    Kill switch £15
    Rear subframe (standard colour) £60
    Rear subframe (red R) £90
    Rear subframe (shot blasted silver) £100
    Rear subframe (motoholders ally) £130
    Wheels with discs £300
    Wheels with no discs £250
    Black nissin calipers £90
    Venhill front brake lines yellow £20
    Domino quick action throttle (custom made) £90
    Translogic race quick shifter £110
    Brembo RCS 19 (gravel rash only cosmetic) £125
    Brand new still in the box yuasa battery £30
    Brembo M4 calipers R model £350
    Standard clutch £30
    Standard clutch lever £10
    Standard clutch lever with perch £20
    Rear axle £10
    Front axle £10
    Please request photos as to many to post
    All prices are posted
  2. Bigmac
    Bigmac
    300
    Updated parts list
  3. MotoMyles
    MotoMyles
    5
    interested in the genny case. just confirming its the left hand side and will fit an 07?
  4. Bigmac
    Bigmac
    300
    Should be the same from 06-12
    You want the case without the genny and cps in it? Can you see the photos? It has had the paint striped by the glue from the cover but it is solid
  5. Bigmac
    Bigmac
    300
    More parts added, not sure why the new parts I’m adding aren’t coming up
  6. kiler113
    kiler113
    All parts for 06-12?
  7. Bigmac
    Bigmac
    300
  8. mike_b
    mike_b
    863
    24
    Have you still got the rear mudguard?
  9. Bigmac
    Bigmac
    300
    I do, it has a couple scratches on it
    Yours for £10 posted
  10. mike_b
    mike_b
    863
    24
    Yes please will send you a pm
  11. Bigmac
    Bigmac
    300
