Engine swap.
Discussion in 'Maintenance & Tweaks' started by oldgit, Nov 7, 2019.
  1. oldgit
    oldgit
    Is there any reason why I cant just drop a 2012 lump into an 06 daytona using the 06 fuel injectors and ECU and 09 headers?
    CPS, gear position switch, oil pressure , engine temp, all the same connections or off 06 lump.
  2. all the connectors etc are the same,
    I presume they have a different map in the ecu tho?
    For the extra money it’s gonna cost I’d just change the loom & ECU personally (it means the clocks too)
    Atleast you’ll gain the plug & play QS wiring.
    I have the later parts for sale or if you like-
    For £60 I’ll swop your 06 loom, ecu & clocks for a 2010 set
  3. oldgit
    oldgit
    I only wanted to run the engine up quickly. To take a quick vid as Im going to be selling the engine
  4. That makes sense,
    Just go for it mate.
