Fuel pump interchangability?
Discussion in 'General' started by subaruzi, Jan 5, 2020.
  1. subaruzi
    subaruzi
    I think I need a new fuel pump for 2009 Daytona. I'm looking at different pumps and looks like D675 and ST3 09-12 are interchangeable. Are any of the other years the same? Particularly 13+ as there's a lot of those.
    Part number 101962-0603
    Or T2401977
    Depending
    Thanks in advance
  2. No they are not
    If you are really keen the difference is the pins on one of the plugs is reversed
    Alternatively I think I have a spare
  3. subaruzi
    subaruzi
    I'll buy spare from you but I'm in the US. Is shipping pain in the neck? eBay has a few available.
  4. In the mix
    In the mix
    217
    10
    Exactly the same, apart from 2013+ are 3.5 bar fuel pressure instead of 3 bar
  5. The pins are reversed so not plug and play
  6. subaruzi
    subaruzi
    So just pumps at higher pressure? Any problems using them for earlier bikes?
  7. In the mix
    In the mix
    217
    10
    06-12 are fine in any of them years , you don’t want to be running a 3 bar when it should be running 3.5 bar though as there won’t be enough fuel injected
  8. subaruzi
    subaruzi
    Awesome. Thank you for help.
