Indicator problem
Discussion in 'General' started by BridleA, Dec 28, 2019.
  1. BridleA
    BridleA
    Hi,
    Sorry if this has been asked before, I've searched the forum but can't seem to find an answer.
    My bike has been converted to LED indicators before I bought it and everything worked fine until a few months ago. All of a sudden my indicators have stopped flashing once my bike gets warm and I can't work out why . At first I thought it was because of the wet weather and maybe water was getting into the flasher relay but I've coated it in WD-40 and it's still doing it.
    Any help would really be appreciated thanks.
  2. scaramanga
    174
    id say your flasher relay is sticking once it gets warm
    try moving the relay away from the engine see if it helps or replace the relay
    make sure the connections are good
    I had a few issues after 1 connection started to break away
  3. BridleA
    BridleA
    Thanks I will give it a go tomorrow
  4. StMarks
    821
    Also have a look at which flasher relay is fitted, some of the "aftermarket LED flasher relays" can be rather erratic & troublesome .
  5. BridleA
    BridleA
    Think I may have cracked it! The relay was hanging free and resting on the engine, I've repositioned it away from the heat and it seems to have worked, for now at least
  6. StephenP
    175
    Worst case is buying a new one and they're cheap as chips.
