MAP sensor error
Discussion in 'General' started by Rihards Ziemelis, Mar 18, 2020.
  1. Rihards Ziemelis
    Rihards Ziemelis
    Hi guys,
    Hope anyone can help me out.
    My Daytona came up with an error code for Manifold Absolute Pressure.
    Would it be something to do with the sensor itself? vacuum lines? or wiring?
    Is it T1292015 that needs changing? if so, where its located?
    Thanks
  2. StephenP
    178
    That'll be the one under the tank. Just at the bottom of the airbox I believe.
    Chances are the rubber hose isn't connected under it.
  3. Rihards Ziemelis
    Rihards Ziemelis
    Thanks,
    I'll check them all over the weekend. The error came up after I changed spark plugs, maybe just forgot to reconnect everything.
  4. StephenP
    178
    Bike won't idle if the hose is off. And it's easy to forget.
  5. Rihards Ziemelis
    Rihards Ziemelis
    That's exactly what's happening, she is not idling, cuts off straight away.
    At the start up when throttle is kept open for a few seconds at 6k rpm she idle fine.
  6. StephenP
    178
    Rubber hose it is then
  7. Rihards Ziemelis
    Rihards Ziemelis
    It was the rubber hose. Thanks for your help. Now its ziptied the the sensor. And I have a spare sensor in case I need a new one.
    All errors cleared and no engine management light.
  8. StephenP
    178
    Great news. It's always something simple and an easy fix with no issues
