Rear axel stuck - any ideas?
Discussion in 'Maintenance & Tweaks' started by Benjimon, Jul 6, 2019.
  1. Benjimon
    Benjimon
    D675 (now blue) rear axel is stuck and won’t come out, no matter how many times I ask it with the mallet.
    Spinning freely, right until I torque it up to 110nm. In fact, anything about 80nm seems to seize it up.
    Done everything same as usual, checked it twice, and the bugger just won’t shift.
    Anybody had this, or any tips?
    • Dumb Dumb x 1
    809
    :-?? Fwiw I've had to swap my wheels round many dozens of times, & never once had a problem with removing my axel.
    Do you think it could have got wet when it was last out, and perhaps the damp has caused it to adhere to the inside of the bearings?
  3. Benjimon
    Benjimon
    It’s been in the garage under a cover so I don’t think so - but maybe the inside of the bearings was damp. I’ll get the wd40 going on and see if that helps
  4. Did you miss the spacer out in the back of the sprocket carrier? If you do that when you try to torque it and can seize up.
    Try lifting the wheel up (wedge something under it) when you are hitting the spindle to take the weight off and it might get it moving.
  5. Benjimon
    Benjimon
    Cheers Peggy - I think it out all the spacers in tights, though there is a couple mm gap between swingarm and spacers with no nut on, so maybe I’ve done a mess of it.
    Tried taking weight off and that didn’t do the trick so I’m gonna try and WD40 it into submission, get a bigger hammer, and if that fails go crying to the garage...
  6. Bigmac
    Bigmac
    4,723
    280
    I never use a hammer on my rear or front axle and it makes me cringe when people do!
    I realise you probably need to here but make sure you work out the issue and don’t use a hammer to put it back in.
    The only issue I’ve had on track and I’ve seen others have are the captive spacers sometimes are a little tight when new and that causes the axle to get stuck, I clean them up with some emery cloth before I fit new sets.
  7. Benjimon
    Benjimon
    I know what you’re thinking bigmac, but nothing else seems to be working.
    Suspect I’ve got one of the spacers backwards and it’s jammed up in the bearings, and not for shifting... so I’ve been to b&q and got me a big lump hammer and a block of wood.
    Wish me luck!
  8. Benjimon
    Benjimon
    Still no joy. Piece of wood and a big lump hammer managed to move it about 20mm but still not free and can’t get it any further - or back in properly. The spacers at each side can move freely and no amount of lube is making a difference. I think the bearings inside the hub must have become compressed onto the axle and so it’s gonna take a lot more hammer that I can do.
    Next call - garage
  9. Benjimon
    Benjimon
  10. Benjimon
    Benjimon
  11. Bigmac
    Bigmac
    4,723
    280
    If I was at work I’d say get some heat on it but that would do a lot of damage
    There is something definitely wrong for it to get stuck there
    You might have to get a solid drift like a socket extension and just beat it
    You will cause damage but it’s got to happen now
    I have an axle that I can sell you
  12. StMarks
    809
    The distortion you've created by hammering the threaded end lopsided, may well cause it to bind at that point too when you eventually get it moving. :((
    Fwiw I would lean the bike on it's left side, then splash some PlusGas (or similar release agent) onto the shaft that you've managed to get that 15mm or so out.
    Let it run down the axle shaft, plenty of it.
    Leave it a while to work in.
    Then take your new lump hammer, and tap that stub you've moved out back home. -Hopefully that will put some of the release agent inside the point that is binding.
    Next flip the bike back over, more PlusGas onto the threaded end, allow it to work down the shaft, and then try tapping it out again.
    If it locks up again, flip it back over & repeat.
    Lastly, looking at that thread, I strongly suspect you're going to need to take up Bigmac's offer.
    Good luck
  13. In the mix
    In the mix
    198
    9
    I would angle grind the head off and knock it through from the non threaded side
  14. Benjimon
    Benjimon
    Good news - the good old boys at Shorrocks garage have got the spindle out, and we’re all going to be just fine - however there was a spacer missing somehow - no idea how it’s survived this long without it, and if I dropped it last time changed wheel then no idea where it’s gone.
    Does anybody happen to have a spare ‘stepped spacer’?
    (Item 24 on the diagram. None avail @ triumph)
  15. StMarks
    809
    Good news indeed mate, fwiw that was the spacer that @675peggy was referring to initially. If everything has survived undamaged you've been spectacularly lucky imho. That same mistake has seen chewed up swing arms, knackered sprockets etc ,,, in the past.
    I think I only have one spare myself, and I'm rather reluctant to be without.
    How much are they from the stealers.?
  16. That's the one! Commonly missed out when swapping wheels, you can normally find one on eBay but sure someone will have one on here.
    I'd put some new bearings in that wheel and cush as a min!
  17. 0S2
    0S2
    4,030
    702
    Great news you got it out and when I did a search on "Spacer, Stepped T2010492" it seems to be fitted on quite a few bikes and available from a few places, mostly EU I have to say but they are out there.
    I did look in my spares box but I only have the one.
  18. 0S2
    0S2
    4,030
    702
    If you look at this page, the same part number is list as item number 8 and is on a street twin.
    Hope I got that right as it is early for me :)
