Sorry one more question, relay sub harness
Discussion in 'Maintenance & Tweaks' started by oldgit, Nov 8, 2019.
  1. oldgit
    oldgit
    Last question I promise (until the next one). On the sub loom for the pump relay there is a small black 2 pin connector. Can anyone confirm where this plugs in?
  2. I can't remeber off hand. Are you running a race ecu by any chance
  3. StMarks
    833
  4. Well done StM. That was in the back of my mind, I remeber reading something about swapping round two pins in a plug to get a race ecu working on a std loom
  5. oldgit
    oldgit
    Hi Stmark, I found that thread earlier, unfortunately it doesnt help me. I have a 2006 wiring loom with the additional fuel pump sub harness.
    So, the sub harness has the loop for the fuel pump and then a couple of smaller connectors (black and white) that obviously loop something else to supply power to the relay. Its thus that im not 100% sure on. The
  6. StMarks
    833
    So, I see.:
    The 4pin relay
    Metal bracket, Screw & cable tie
    Loom cable with,,,:
    Brown female pump plug connector
    White male pump connector
    Large black relay socket
    Black SAI solenoid piggyback connector
    White SAI solenoid piggyback connector
    So I assume you are asking about the SAI plug for supplying the pump's drawn power to this sub-loom.?
  7. oldgit
    oldgit
    You've come up trumps again Stmark
