Speed sensor
Discussion in 'Maintenance & Tweaks' started by g6xer, Feb 13, 2020.
  1. g6xer
    g6xer
    15
    I've burnt my speed sensor out can it be bypassed??
    822
    If it's only a sensor, can't you simply disconnect it (it's not feeding back info to anything ).?
  3. Bigmac
    Bigmac
    4,826
    290
    The bike won’t start apparently
    • Informative Informative x 1
  4. StMarks
    822
  5. GazP
    GazP
    444
    Is it a big job to replace?
  6. Bigmac
    Bigmac
    4,826
    290
    It’s easy job but not when you are in Spain on a trackday
  7. GazP
    GazP
    444
    Bugger
  8. g6xer
    g6xer
    15
    So lookslike you can unplug a speed sensor and run the engine but now it wont idle correctly
    When its warm it will run about 700 rpm but if I blip the throttle it will stall
    I'm a bit stumped now
  9. StMarks
    822
    I wonder if that could perhaps be something unrelated.? Just coincidence.??
    The EXUP valve isn't stuck open perhaps.
  10. g6xer
    g6xer
    15
    Exe up been disconnected but I did damage the cables to it
    We think it might be the fast idle controller now
    Just wont idle
    Going to run it on track tomorrow and see what happens
    The loom is so bad every time I'm under the tank something else breaks
  11. g6xer
    g6xer
    15
    Is it common for the idle stepper motor to just fail??
  12. StephenP
    175
    It's does happen, though run a test via tuneecu and you'll see it move. Had it once where the arm moved it was actually the part it moved that was stuck. Little wd40 and a wiggle to loosen it up.
  13. g6xer
    g6xer
    15
    Unfortunately I'm out at monteblanco so no tuneecu but will start spraying the shit out of everything
    Cheers for the advice though
  14. StephenP
    175
    You'll hear the noise but just watch to see if the arm moves when you turn the key on
  15. g6xer
    g6xer
    15
    Is there anyway in a crash I could of upset the idle speed
    I've pretty much checked everything
    The only thing different is the speed sensor is unplugged
  16. Bigmac
    Bigmac
    4,826
    290
    I’ve seen throttle position sensors die in a crash
  17. StephenP
    175
    Just had a light bulb moment, check under the sensor at bottom of the airbox, rubber hose attaches there. Has that come off in the crash?
  18. g6xer
    g6xer
    15
    All rubber hoses on a good friend mentioned this right at the beginning I did find a brass nipple with nothing on which we plugged but still no difference 20200214_150016~2.jpeg
  19. g6xer
    g6xer
    15
    Will that stop it from idling??
  20. Hi g6xer, sorry to hear you've not got it sorted yet. It was me you talked to in the garage next door, about my son having a spare. Hope you have more luck today !!
