'13 Wheels on 06-12
Discussion in 'Chassis' started by 675peggy, May 21, 2015.
  1. 675peggy
    675peggy
    241
    I'm now running a set of 2013 Daytona wheels on my 09 SE.
    You need to make a couple of mods but nothing major.
    You need to use the wheels and discs from the 13', 06-12' discs won't work.
    On the rear you need to space the rear disc out 4mm, I had been running 4 individual spacers but am now using 2 standard triumph pulsar rings, much simpler.
    You also need to file the Caliper carrier to clear the bolt heads, I filed the writing off the back of mine (so its flush) and its clears nicely.
    Apart from that they slide right in!
