2006/2007 675 Spec
Discussion in 'General' started by Craig, Oct 31, 2007.
  1. Craig
    Craig
    Administrator Staff Member
    4,861
    223
    General information
    • Model: Triumph Daytona 675
    • Year: 2006
    • Category: Sport
    Engine and transmission
    • Displacement: 675.00 ccm (41.19 cubic inches)
    • Engine type: In-line three
    • Stroke: 4
    • Power: 125.00 HP (91.2 kW)) @ 12500 RPM
    • Torque: 72.00 Nm (7.3 kgf-m or 53.1 ft.lbs) @ 11750 RPM
    • Compression: 12.7:1
    • Bore x stroke: 74.0 x 52.3 mm (2.9 x 2.1 inches)
    • Fuel system: Injection. Multipoint sequential electronic fuel injection with forced air induction
    • Fuel control: DOHC
    • Ignition: Digital - inductive type - via electronic engine management system
    • Starter: Electric
    • Cooling system: Liquid
    • Gearbox: 6-speed
    Transmission type
    • final drive: Chain
    • Clutch: Wet. multi-plate
    Physical measures
    • Seat height: 825 mm (32.5 inches) If adjustable, lowest setting.
    • Overall height: 1,109 mm (43.7 inches)
    • Overall length: 2,010 mm (79.1 inches)
    • Overall width: 673 mm (26.5 inches)
    • Wheelbase: 1,392 mm (54.8 inches)
    Chassis and dimensions
    • Frame type: Aluminum beam twin spar
    • Rake (fork angle): 23.5°
    • Front suspension: 41mm USD forks with adjustable preload. rebound and compression damping
    • Rear suspension: Monoshock with piggy back reservoir adjustable for preload. rebound and compression
    damping
    • Front tyre dimensions: 120/70-ZR17
    • Rear tyre dimensions: 180/55-ZR17
    • Front brakes: Double disc
    • Front brakes diameter: 308 mm (12.1 inches)
    • Rear brakes: Single disc
    • Rear brakes diameter: 220 mm (8.7 inches)
    Other specifications
    • Fuel capacity: 17.40 litres (4.60 gallons)
    • Color options: Scorched Yellow. Tornado Red. Graphite
