Anyone used these
Discussion in 'General' started by Ff6022, Nov 2, 2017.
  1. Ff6022
    Ff6022
    168
    As title says, anyone used these for there position lights on an 09' Daytona. Any issues? Just wanna make them white over yellow.
    Also if anyone know a good H7 white light to replace the OEM yellow one that would be great. Also don't want the hassle of the HID's.
    859
    LED's are a developing technology, and eventually will replace tungsten all together. I have changed all my side lights, indicators etc... on all my vehicles for LED for quite a while.
    However I have not yet found any LED plug & play replacement light sources that I feel are sufficiently powerful to replace headlamp bulbs.
    It will happen, after all some new cars can come with LED headlamps now.
  3. martin675
    martin675
    3,577
    186
    The thing i find with led is they are powerful short projection but they dont throw light as far as a halogen does.
  4. martin675
    martin675
    3,577
    186
    Philips is a safe bet though quality wise. Philips, osram are some of the best.
  5. triple7
    triple7
    80
    Recently bought some Philips Ultra Vision bulbs for my car and genuinely impressed. Nice white light and light output seems marginally better. Tried Osrams before on the recommendation of others but wasn't very impressed tbh, felt they look exactly the same as normal halogens but just my opinion.
  6. Ff6022
    Ff6022
    168
    [​IMG][​IMG][​IMG]
    I just did it anyway. Makes my dip beam look yellow now though and that's meant to be a Bosch white little
  7. Stu675
    489
    HID is really not much hassle. just drill 25mm hole in the cover (they come with a rubber bung) then it's plug & play.
    Great for dipped, but I wouldn't use for full beam (unless it was an H4 application)
  8. triple7
    triple7
    80
    As Stu says, I've added a HID to the dip beam side and it makes a world of difference!
  9. cpszx
    471
    i am running 2x HIDs on my Sprint and they do make a big difference.
    although have added some strategic tape to mask the glare that they give off, to be kind to drivers...
  10. Me to hid on dipped beam and supper bright side light bulbs.Hid quite easy to fit makes a whole lot of difference
