Daytona clutch in a Street Triple RX
Discussion in 'Chassis' started by Crispy, Apr 6, 2016.
  1. Crispy
    Crispy
    70
    I've read on various threads on various forums that the standard slip assist clutch from a 675 Daytona will fit into a Street Triple R/RX. These clutches come up on eBay once in a while and I've been keeping an eye out for one, this has just popped up: eBay Daytona clutch link
    As I'm not 100% sure of the fitment and which years are compatible? Could anyone shed a bit of light on it for me please
    Crispy
  2. I'm pretty sure that anything after 2013 already has the slipper clutch
  3. Crispy
    Crispy
    70
    The Street Triple doesn't have a slip assist clutch, just a standard item
  4. martin675
    martin675
    3,577
    186
    I tried as hard as i could with the rx to get the rear hopping a bit i was convinced it had a slipper but it doesn't, it really doesn't need one in my opinion. I gave it allot if abuse and it seemed to handle it part of the reason i kind of went of it.
  5. Was that Coz ur fat arse was on the back. No hope of it hoping around
  6. martin675
    martin675
    3,577
    186
    Says the man who leant on his fancy air bag and it went off!
  7. Crispy. You need a clutch from a Daytona 13 on then. Easiest way to tell them apart is your original clutch will have six bolts that hold on the outer plate and the later ones have three. Also you only need to change the in basket and plates not the outer basket which makes things easier
