Don't do what i did!!!!!!!!
Discussion in 'Maintenance & Tweaks' started by keithspurs2000, May 11, 2009.
  1. keithspurs2000
    keithspurs2000
    I took my sprocket off yesterday to scrub all the crap off it and when putting it back on i've stripped two of the studs. Gotta bring it to the dealer to get fixed. If they can get the studs out it going to be an easy fix. I need a new sprocket carrier it'll be an expensive mistake me thinks. i read the wrong torque setting of the service manual. I am a fool.
  2. Rowly
    Rowly
    870
    Don't want to rub salt into the wounds Keith but in hindsight wouldn't you
    have been better off leaving it attached to the carrier just to clean it?
    What torque setting did you use to nip them up? it should be 55NM
    You must have given it some to strip the studs, as you say could be
    emptying your wallet big style, don't do yourself down it could happen
    to anyone of us, the only positive note is by telling us about your
    experience we can all learn from it, good luck with the cost of ;)
  3. keithspurs2000
    keithspurs2000
    mate funny enough my torque wrench was set to 55 but theres another torque setting of 30 for that aswell. i assume now its 30. 55 fucked it up.
    rear sprocket to socket carrier is 55
    rear sprocket studs to socket carrier is 30
    to right rowly i wont take it off again. it is pretty clean though.
  4. Rowly
    Rowly
    870
    Hi keith, just looked at the torque settings again in the repair manual and it states the following
    Rear sprocket to carrier 55NM
    Rear sprocket studs to sprocket carrier 30NM use new fixings.
    The way I would interpret that is 55NM for the nuts & 30Nm for
    the studs only if you are replacing them, its very ambiguous?
    Is that how you read it?
  5. Rowly
    Rowly
    870
    Our posts have crossed, looks to be right then, I would maybe get your torque wrench
    checked out for calibration :?:
  6. andysjt
    andysjt
    1,476
    24
    was going to take my chain off yesterday to clean it , but its another one of them things thats best left on the bike untill you need a new one, coz you need a tool to split it ,then a new link to re- assemble it , was going to attack it with a screw driver untill i read the manual , then decided to leave it on after all
  7. Rowly
    Rowly
    870
    Very wise Andy, splitting the chain on my push bike years ago was bad enough :x
  8. keithspurs2000
    keithspurs2000
    the torquewrench was brand new. that was first time ive used it. gonna go for 30 this time i think rowly.
  9. Edski675
    Someone's been eating a lot of spinach :D
  10. Funnily enough I cleaned my rear sprocket and chain last weekend too! I left the sprocket on the wheel though. How do you know how tight to do the nuts? The only ones mentioned in my manual are the rear axle (110Nm) and the adjuster bolts (27Nm). Anyway, after riding the bike for a few hours the chain and sprocket look almost as filthy as they did to start with!
  11. keithspurs2000
    keithspurs2000
    ive got all the critical torque settings.
    i used 55nm and buggered it up so ill use 30 next time. if it is supposed to be 55 either the studs are shit or my brand new torque wrench is shit.
  12. Rowly
    Rowly
    870
    There is a workshop manual available with all the torque settings and all the information
    you need on disc for your D675,I got mine on ebay for around £3, I'm not certain but they
    maybe a copy to view on here somewhere?
  13. keithspurs2000
    keithspurs2000
    i can email to you supreme if you want it
  14. Stu
    Stu
    716
    Sh1t luck Keith. I hope it's not too costly for you.
  15. spike
    spike
    396
    have they said when there going to repair it for you?
    dont worry if you cant make wednesday i will be out thursday as well if you can make it then ,
    if not we will take a rain check keith ;)
  16. Oh .. I think I might have downloaded that a while ago. I'll have a hunt around.
  17. keithspurs2000
    keithspurs2000
    ok it seems ive got away with it. the dealer has replaced the studs. just need to go pick the sprocket carrier up. phew.
  18. keithspurs2000
    keithspurs2000
  19. Stu
    Stu
    716
    Result. It could have been worse. I bet you are a happy bunny now :)
  20. keithspurs2000
    keithspurs2000
    oh yes. i also know how to use my torque wrench properly now. read the instructions the next time keith.
