Error code.
Discussion in 'Maintenance & Tweaks' started by RichyBrown, Feb 20, 2016.
  1. RichyBrown
    RichyBrown
    P1080 - Exhaust control valve actuator circuit malfunction.
    Does anyone know how to fix this?
    Cheers.
  2. I'd guess the exup valve is stuck/sticking. You could try freeing it off but best to have it wired in the open position or have it cut out
  3. Definitely the exup servo
    Easiest to take the wires off mate and it will flick open inside then just weld or lock tight the nut, disable via the tune ecu
  4. RichyBrown
    RichyBrown
    Brilliant. Going to sort it tomorrow morning.
    Thank you!
