hi all! fitted a new nut and washer to my front sprocket shaft this evening i was advised to torue the nut up to 62lbs i set the torque wrench but even with me giving everything and my missues standing on the rear brake i could not reach 62lbs! so i have left it as it is with the washer bent over the nut on 1 edge of the nut can i assume that the nut will stay tight and that the wrench torque settings are naffed on the wrench? will it be ok to ride as i have tighten it up as much as i possibly can or should i get it checked at a dealer?
Piece of 2x2 softwood through the spokes of the wheel did it for me, just let lock up against the swingarm and then tighten the nut to the req'd torque.
