Front sub frame removal (T2700717)
Discussion in 'General' started by Gremlin, Jun 29, 2023.
  1. Gremlin
    Gremlin
    37
    Hi all,
    Does anyone know how to remove this part? I bent mine in a bit of an off!
    This is the bit that holds the dash and the headlights.
    I can see there are four external bolts but I can't see how to get to the nuts inside of the unit!
    Thx.
  2. scaramanga
    190
    never removed it but if you cant get to the other side the nuts may be welded on or the item is threaded
  3. Gremlin
    Gremlin
    37
    The bolts loosen but then they just spin round and won't come out.
    I'm going to remove the tank and the airbox and try to get access to the nuts from inside the headstock.
    Failing that it may be a case of cutting off the bolts and fitting the new part with self tappers?
    Thx.
  4. Could be they are Rivnuts on the inside? Notorious for spinning.
    You'll probably have to cut the bolts if so.
  5. scaramanga
    190
    i have a Rivnut kit
    i agree most factory fitted are crap ive had better results with any ive fitted
    cheaper kit
    https://www.ebay.co.uk/itm/364271972052?
    better kit but more expensive
    https://www.ebay.co.uk/itm/225630510394?hash=item3488a05d3a:g:bMgAAOSwXldi1nHy&amdata=enc:AQAIAAAA4IsLeX5hIU4oRO5eu1iD8v3WD/BRoSLbQREZ+XpZ3BAAHYNFZF8tjFBkMMUWvURNscOTHXFU9eAGQt+YOQDhG74ydltiPsgOVraYklasq5KKNmPVJ7+6GZN1wMBx8ciCpzQu0Ty3G1iMvq+PlkfCvVRNcMtGjAXKlg12rY7IP48UXW+NzxKnP7OQlrIt1HMSAopjnUghzVqn2c/1K1KIjqglq+VBzFs7UwFwngjDQeS14U8JuvM4EScjLu+co6RvCGvSM/EDQZIXRCgjL9Y/4l8uUSn0xiLxfyI/9tRBpVD2|tkp:Bk9SR4rEwomjYg
    i have both types first type is good enough but 2nd better and easier to get good tighter fit of the threaded rivet
    you can also re tighten some allready fitted by using a longer bolt and 2 nuts if you manage to get the original bolt out
    sure theres a few vids on you tube
  6. Gremlin
    Gremlin
    37
    Here's the exploded view from the Fowlers website. Looks like standard nut/bolt?
  7. Gremlin
    Gremlin
    37
  8. Gremlin
    Gremlin
    37
    I finally figured out how to do this. It's quite simple.
    Just remove the air intake (part 22) and this gives access to the inside bolts of the front sub-frame!
    However, I managed to drop a nut which went behind the headstock and probably dropped into the air box.
    I know there's an air filter which will prevent the nut from entering the engine but I feel I should make the effort and try to fish it out?
    It will mean removing the tank and airbox tho.
  9. StMarks
    And you just know that you will do all that work, and then find the nut on the floor behind something...:pp
    But if you don't, it's just going to play on your mind..8-))
  10. Get an extending magnet to fish the nut out.
    Sent from my SM-G960F using 675.cc mobile app
