Fuel Relay
Discussion in 'Maintenance & Tweaks' started by midgeman, Jan 8, 2009.
  1. midgeman
    midgeman
    Discovered recently that some 675s have had a Service Recall for the Fuel Relay aparently the Relay fitted at the factory can occasionally cause the ECU to blow so Triumph have decided it is cheaper for them to fit a different type of Relay rather than have the cost of fitting a new ECU under the warranty agreement.
    To find out if yours is one of the machines with the problem contact your Triumph Dealer and quote the VIN number and they should be able to tell you if your pride and joy has any outstanding recalls on it.
    Mine is going in as soon as the weather picks up (I never use it when the salt is on the road) the dealer I contacted (Windy Corner) just round the corner from the factory said it takes about half an hour to do the work and they need about a weeks notice to get the kit from Triumph.
    Midgeman.
  2. Craig
    4,884
    226
    doh! not good news for some. thanks for the heads up. :)
