I've got some HIDs but I can't work out how to fit the damn things :roll: So as a temporary measure I was looking for brighter ornery bulbs, found the H7s in Halfrauds on BOGOF but I couldn't find the H9, asked on their website and this is what they said: http://answers.halfords.com/answers/402 ... stions.htm Anyone know where I can get one? Pref 90% brighter to match the H7?
Anyone tried these? http://www.autobulbsdirect.co.uk/h9-bulbs.html Look OK - £18 for 2 is pretty good innit?
I picked up a set of Osram bulbs at the NEC, the blue ones, I would think if you tried Demon Tweaks, in Wrexham industrial estate Ed, by the way the post code for Demon Tweaks will not come up on your sat nav, in case you thought to drop in there, you will have to call or use a map for directions, Tis a labyrinth of roads on that industrial estate.
What make are the HID's. The hardest bit should be mounting the ballast. but apart from that its a plug and play device like putting a filter on your broadband. Maybe we can have a how to section on here so if people feel obliging they can do step by step photos if fitting stuff and post on here for reference to other users.
