new LED indicators
Discussion in 'Maintenance & Tweaks' started by Iron Urchin, Jun 23, 2008.
  1. Iron Urchin
    Iron Urchin
    hello, i want to swap my original rear indicators for some new LED jobs, am i going to have problems with the flash rate ?
    can this be solved by changing the relay ?
    if so, where is the relay located ?
    thanks guys.
  2. Iron Urchin
    Iron Urchin
    hmmm.... nobody else come across this problem then? :?
  3. Stu
    Stu
    716
    Not sure about the flash rate but if the leds are the same voltage it shouldn't be a problem. There are 3 relays under the nearside fairing infill pattern, if it not there then try under the seat.
    You could even download the service manual from www.675.cc :)
  4. Iron Urchin
    Iron Urchin
    that's brilliant, that manual will come in really handy :D
  5. Zmok
    Zmok
    You need either a Led flasher unit or some 18w resistors otherwise they will flash too fast!
    They look like this
  6. Army_Roofus
    Army_Roofus
    10
    These signals from British Customs need no changes what so ever. Just plug and play. They already have the Triumph connectors on them and any load work takes place in the signal unit itself. Nothing else to hook up.
    http://www.british-customs.com/triumph- ... -1510.html
  7. Iron Urchin
    Iron Urchin
    thanks Roofus, i really like those........i was actually thinking about the rear indicators, but when i've got some spare cash i will seriously consider those aswell.
  8. Army_Roofus
    Army_Roofus
    10
    Yes, you said that didn't you and I blew right over that. Sorry about that mate.
    It has been a while since I have dealt with stalk signals. If you are doing a fender eliminator kit you can check out what competition werkes has.
    http://www.competitionwerkes.com/
    Mike
  9. jimjam39
    jimjam39
    501
