Tags:
Removing the Catalytic Converter
Discussion in 'Maintenance & Tweaks' started by matthew montano, Dec 13, 2019.
  1. matthew montano
    matthew montano
    Hey guys! I just need some knowledge on doing this. Im planning on removing the Cat on my Daytona 2012 675r. I've found this map on tuneecu (20593) is this the right tune for it? Or is there a different tune that I should use when removing the cat? And if I do this should I also remove the exup valve?
