Track handle bars
Discussion in 'Chassis' started by moanthebairns, Jul 9, 2015.
  1. moanthebairns
    moanthebairns
    27
    Need a new set for the track, anyone recommend any.
    What size, does the standard grips etc fit onto it.
    How about the location pins for starter etc.
  2. Diamonds are cheap, Renthals/Woodcraft are good.
    you need some which you can just take the bar out if/when it needs replacing.
    If you can get ones that you can take the clamps off without dropping the forks they are more convenient, however you will need to drop forks anyhoo to get std bars off.
    aftermarket bars will not have location pins, you will have to use your skill and judgement to line them up.
    std grips will fit any of the bars, but you are better off getting Renthal grips.
  3. Any 50mm clip on will do mate. Get some spare tubes too
  4. moanthebairns
    moanthebairns
    27
  5. Yes mate SES 50mm clip ons and a couple of spare tubes and you'll be sorted.
  6. jfow1
    jfow1
    240
    24
    The T3 ones are good and cheaper also than Main brands
  7. using those ses bars you will only ever be able to use their bars. (unless you carry a drill about with you)
    if you get clip ons where the bar is clamped in you will be able to bolt on any bar in the pits
  8. moanthebairns
    moanthebairns
    27
  9. moanthebairns
    moanthebairns
    27
    I cant see anything on T3 website for aftermarket clip ons
