TRS linear linkage
Discussion in 'Wanted & Swaps' started by RL_675, Apr 8, 2020.
  1. RL_675
    RL_675
    Hi all,
    i am looking for the linear linkage from TRS. I thought i would ask here first just incase someone has one going.
    thanks. Rich
  2. DaveJPS
    DaveJPS
    181
    13
    I've got a set of T3 linear suspension plates without the shorter dogbone (if I can find them in the garage)
  3. RL_675
    RL_675
    Dave, that could work. do i need the shorter dog bone as well for this to work or does the standard one do the job?
    i have also seen there are variable adjustment ones but i am not sure about these for track.
    thank you
  4. DaveJPS
    DaveJPS
    181
    13
    You need the shorter dogbone to solve the ride height issue (the plates on their own jack the back up) and it can't be solved by pulling the forks through the yokes. According to T3 these were designed to be used with an adjustable dogbone
  5. RL_675
    RL_675
    If you can find them how much do you want for them?
  6. DaveJPS
    DaveJPS
    181
    13
    I was thinking £55 posted (UK)
  7. RL_675
    RL_675
    £50? nice round number. Also did you happen to find them?
  8. DaveJPS
    DaveJPS
    181
    13
