Re: Some changes to KDR triumph Few more little bits done today, new rear brake line fitted just need to bleed and nice little res sock
Re: Some changes to KDR triumph Had them made up is one piece of vinyl..........nige at pittys make them up
Re: Some changes to KDR triumph Pitty's is definitely top notch and can do individuals if you want the base bellypan to show through. As per my pic.
Re: Some changes to KDR triumph Looking very trick, spotted the Ears Motorsport on the belly pan, you from the mac area?
Re: Some changes to KDR triumph Cheers johnny...........yeah I worked on the superbike side till went bump in 2011
Re: Some changes to KDR triumph Its it that long ago since they went Bump??? Damn used to like dropping in there on the way though to Donnington from Manchester. Did see it the other day though when i was going to see my Folks in Wigan.
Re: Some changes to KDR triumph Yeah the bike side stopped trading as a company in 2010 and closed in 2011 but the motorsport side is still going
Re: Some changes to KDR triumph Well as winter approaches and tax runs out in next few weeks, I am planning on what to do over winter months in the man cave...........i have a couple of ideas on things to do. Wheels may change doing some research in to a few things?? Subframe will be having a refresh as is rear braking system along with a full strip and clean some more silicone hoses, exhaust work and wrapping. Will keep you up to date with changes as they unfold
Re: Some changes to KDR triumph Been looking at Ducati and aprilia wheels........doing some research in to see what if any changes are needed to get them on as you can pick a set up for bout £400 ish
Re: Some changes to KDR triumph Lot of work over past 3 days in getting the man cave sorted before starting winter strip down, so floor and walls all cleaned and painted also new work bench put in place
Re: Some changes to KDR triumph Building a little spray booth so can start painting my race fairings and other bits
