bike wont start :(
Discussion in 'Maintenance & Tweaks' started by mikey675, Mar 30, 2011.
  1. mikey675
    mikey675
    Hi, yesturday i dropped my bike on its side in the garage while it was running and it istantly cut out as it was late and dark i left the bike untill this morning to asses the damage. When I went to look at the bike this morning I was quite happy that the crash protection had taken all of the damage. However when I turned the key the engine management light flashed up rapidly and everything went dead. Now when I turn the key I get no response from the bike what so ever apart from the alarm going off when i disarm the alarm its showing a fault code saying loss of power. I initially thought it may have been a fault with the alarm so i disconnected it and plugged in the jumper plug, but there was no change, iv visually checked all of the fuses including the one under the seat they all seem fine, the battery is brand new and given me no problems for 200 miles. Has anyone suffered this problem of have any ideas what to check next.
    Cheers mike
  2. Captain Steffydog
    I'd say try it again and it should be fine, they dont like being on there side, and have a cut off, as the oil etc is in the wrong place etc.
    Now it's been upright a while id guess it will be ok.
  3. Anonymous
    Anonymous Guest
    Test the battery with a Meter if you have one. Just because its new does not mean a drop hasn't damaged it.
  4. Deegee
    Deegee Moderator Staff Member
    7,934
    As GSI says test the battery, if you have a lead acid type you could've lost the acid (electrolyte) if it's drained out the breather overnight :? !
  5. Captain Steffydog
    Definitely should have stood it back up last night, and looked in the morning, they don't like lying down.
  6. +1 very strange decision to leave it on the floor!
  7. Could just be the way he worded it guys. Maybe he picked the bike up but didn't assess the damage till the morning as it was dark in the garage? I don't think anyone would leave a bike on it's side overnight................................would they? :?
  8. geko
    geko
    309
    If the new battery is the same as the OEM one it's a sealed 'Gel' type and can actually be mounted on its side so the bike falling over is unlikely to have affected it, at least in respect to the battery acid.
    More likley a connector or relay somewhere has shaken lose. There are a load of relays/fuses under the left fairing /cockpit infill
  9. Anonymous
    Anonymous Guest
    Mine has the original battery and it's sealed lead acid hopefully it will be something simple the fact the dash still boots must count for something do the daytona have a tilt switch that need resetting?
  10. If it was you and you did leave it on the floor all night, would you admit it? I wouldn't lol
  11. isnt there some kind of tilt switch that shuts everything off if the bike goes down... :?:
  12. Captain Steffydog
    Yep I would admit it, if thats what I did.
    Maybe a switch Nige.
    I know that when I dropped my old Kwak er6f, it wouldn't start again straight away, probably a good 1 min before it went chug chug again.
  13. tommo5600
    tommo5600
    748
    yeah there is it's located behind the clock mounting bracket, i don't think you have to do any sort of reset on it perhaps you could disconnect it turn the ignition on then off then reconnect and try again.
  14. Anonymous
    Anonymous Guest
    Hey I said switch 1st (walking off to sulk)
  15. tommo5600
    tommo5600
    748
    Awe buddy it's ok n :lol:
  16. aaahhh mate,, i heard you say it first, i was just backing you up is all :lol:
  17. Anonymous
    Anonymous Guest
    Re: Re: bike wont start :(
    Lol. I'm over it :)
  18. Captain Steffydog
  19. mikey675
    mikey675
    Ha I didnt leave my pride and joy on the floor all night :-S surely nobody is this stupid!
  20. Captain Steffydog
    Er, you'd be very surprised at what some people get up to on this forum!
    Have you not looked at the Twat of the week threads!! Clicky here!
    Anyway, not all bad, i've popped your thanks cherry for you!
