Hi all has anybody got any suggestions on the best chain cleaner and lubricant? I use castrol at the mOment but find it flings off alot! Any suggestions?
I just use cheap chain/brake cleaner... it's the same thing just in a different bottle lol... Then Wurth Dry Chain Lube... no fling
I used some mucoff stuff to clean the chain. The dirt literally falls off mate. I'll have a nose when I go in the garage
I'm with Stu675. Scottoiler all the way. Less messy, less wear on the drive system, less chain adjustments & better lubed chain = less friction = more horses at the back wheel IMO.
I use 'Gunk' degeaser which you can by in Halfords to clean my clean, once dry I use the Wurth dry chain lube. Like the other guy's have been saying, It doe's fling at all.
