Hi everyone, Had my 07 Daytona for roughly two months, had no issues before this. However I came to ride my bike to work today and the bike wouldn't start... exactly the same as in the video . Im not mechanically minded at all so if anyone could recommend a decent mobile mechanic in northants/Bedfordshire to come have a look it would be appreciated. Thanks Ben
Do you know how to jump and/or bump start a vehicle? If so, check the voltage on the battery with the ignition off, and then again with the engine running after jump/bump starting it.
That does sound like the battery is unable to supply correctly when the starter relay demands the voltage draw from it. So, first to check..: Battery flat or duff Main contact terminals on the battery..
