2015 - pliers worked when testing in my driveway but the heat form the track session caused it lock into place. Just took it to my dealer and they have a tool that they inserted into the can and expanded to pull it out - it still needed quite some force. Keen to get a custom baffle to help reduce noise and hopefully be a better fit.
ok cool mate. i've found running the bike for a bit, then getting the pliers on can help. or a set of mole grips.
Heya guys. Trackday virgin here but planning to go that way.Hopefully be picking a few noggins saturday. I notice that the Werkes pipe DB is empty so I was wondering if any1 got a reliable meter on phone or sommit (as I dont have smart phone) that might be able to test mine on the last part of fest run. Can bring baffles along to. Just an idea. Cheers 12
2013 - Arrow slip on with a custom link pipe, (No exhaust valve/servo) with baffle in at MSV at Bedford. A few weeks ago it hit 103DB however the tester had the DB meter pretty much right up the pipe! Normally it is 100DB consistently with baffle in. Baffle out i would say circa 106DB (Guessing).
My 09 ran 98 at oulton the other day That 2 brothers carbon can, no baffle and cat in i was surprised as everyone thinks its daft loud. Gna get a decat over the winter i think any thoughts
think i may have already entered,stock 675r 99db decat with end can baffle101[remus] full race arrows stage3 675r 102 wih full baffle without bloody loud 110 upover
try mark hill MHP . I have full race system with mhp can 99db wihout baffles . clubman can with link pipe was about £220 delivered
2014 Daytona with decat headers, SC Project M2 can and baffle - 100db at a beautifully sunny, blue skied Cadwell yesterday. 4 bars showing on the temperature gauge at the time.
Well after my recent trackday at Cadwell mine registered 98db which I though was good. I’m not sure I had it at exactly 6500 revs mind you. 06 bike Standard headers de-cat and exup removed. 48mm x 2.5mm wall stainless pipe welded in place. MWR race filter. Scorpion slip on race can with no baffle. Running the full arrows fuel map. I made a jig at work to remove the exup and cat. I still have this if anybody needs any 06-08 headers sorting out.
Forgot to add, 2 weeks later and the only difference being it was 5 degrees colder (5 degrees on the day) and I drove straight up to the noise testing guys, no waiting in a queue and the exhaust blew 102 dB ! Make of that what you will.
Fwiw I always let the bike get up to temp before noise testing, as it's definitely noisier when cold.
Anyone done Croft and got away with a torch without baffle? Croft being 102db and the tor being 106db
not get away with it m8 no limits have tester on before grop nduction no pass notrack seen a few warned about removing baffle after testing . under 102 r away home for a wasted day
Reading this has got me pretty worried. Oulton this week - Arrow slip-on with a stupidly tight baffle I’d rather not fit on an 06 bike. I’m hoping it scrapes under the 102..... what revs do they make a triple go to?
Unlikely I suspect, think you'll probably need that baffle (& don't drop the locating screw into the silencer, like this muppet did). When was the silencer last packed.? I think it's 6500rpm (I should know, the amount of times I've been told to hold it at)
I have no idea. Only owned the bike a week. Balls. I was hoping to get away with it. Might as well fit it to save losing my first session to the noise nazi. I suspect once I’ve done a day with the baffle fitted - it won’t come out again.
