Help needed sharpish!!!
Discussion in 'Maintenance & Tweaks' started by Big.h, Jul 13, 2015.
  1. Big.h
    Big.h
    82
    Have a trackday tomorrow and my bike has thrown up an EML light, tuneEcu comes up with code 1108 ambient pressure circuit high voltage or open circuit it won't clear, will it still be ok to use tomorrow?
    Thanks.
  2. Ah :( dude check the air temp sensor wiring on the air box, maybe they have snipped off . That sensor usually causes that code
  3. Big.h
    Big.h
    82
    Ain't had the tank off for years though. Would it not be a safe to use as is?
  4. Try the 3 heat cycles mate see if that kills the codes, if not swap all the fuses out and that may cause the fault to self right
  5. Mine was like that as my sensor had died. I lost a little bit of power when riding it at Cartagena and it was a bit spluttery getting on the power, but overall it was generally fine. Did 4 days on it no real issue. Changed it when i got back
  6. Big.h
    Big.h
    82
    That's kinda what I wanted to here trouble thanks.
