Indicator relay
Discussion in 'General' started by Bl street, Dec 24, 2013.
  1. Bl street
    Bl street
    10
    I am going to fit some led indicators and have been told I need a new relay at triumph they are £55 but I've seen them online a lot cheaper has anyone used cheaper ones or would I be asking for trouble, and merry christmas
  2. Is got one somewhere, will have a look for you
    Sent from my Nexus 7 using Tapatalk
  3. scaramanga
    200
  4. Aren't the led relays for specific models?
    Been told that 06-08 have the indicator relay on the left side under the fairing by the rad hoses?
    Does it work with other models also?
  5. scaramanga
    200
    my 11 plate is fitted in the left side by the rad hose
    basicly a relay is a relay they may mount different but most are a universal fit aslong as the flash rate is right for led or standard type bulbs you can use from different bikes of hand i think the 1 i have is for a r1 but not 100% sure
    you will only need the led relay if you have fitted led indicators off coarse as they were not standard fit
  6. Bl street
    Bl street
    10
    Just had a look to see if I can find the relay there are some near the battery under the seat but how do you know which one the owners manuel tells you loads like how to ride the bike very useful lol . My bike is the 2013 street
  7. scaramanga
    200
    not sure but it is possible the 2013 models allready have led indicators fitted
    hopefully someone who owns 1 can confirm this
  8. The 2013 has the same bulky ones as the older models. You have to purchase the led ones and fit them
  9. Aeolus
    Aeolus
    46
    My 2013 also came with incandescent signals.
  10. SW73
    433
    Imo the triumph led indicators are worth the additional loot. They look great, are extremely visible from a safety perspective and fit perfectly. I found several dealers doing 20% winter discount on parts last Jan which made it doable for me. I think i paid £92 for indicators and relay kit. Transformed the look of my 08my bike. Might be worth a little wait and a ring around...
  11. bionoff
    bionoff
    56
    Not sure if you still need any info, but I fitted led indicators front and rear when i did my clear rear light and melotti tail tidy. Just needed two cheap eBay relays in the circuit, taped and tucked away underneath my pillion seat with the rear light block connector.
  12. D41
    Hello mate...the relay you want is prolly from a '96 VW Golf....they cost about six quid, but you have to have resistors in the line if you want to run LED's, otherwise they won't work right.
  13. scaramanga
    200
    only 1 relay is needed what you have is proberbly inline risistors in which case you would require 2 1 on each side similar to the link below
    http://www.ebay.co.uk/itm/BIKINGEAR-MOT ... 3f0ffe8b92
  14. jcp
    jcp
    895
    Plug and play is the way to go. All you have to do is replace the O/E relay with one intended for the lower power requirement of LEDs. Mine was an e-bay special sold as a Yamaha fitment. Fitting resistors simply tricks the existing relay by adding a load to each circuit equivalent to the wattage of old style bubs and dissipating power to heat.
  15. bionoff
    bionoff
    56
    Sorry, you're right, I was thinking of resistors, not relays!
  16. Bl street
    Bl street
    10
    I finally got round to getting my LEDs today and the relay at triumph was priced wrong only £15 so happy days my tail today's fitted and ill hopeful sort the indicators tomorrow
  17. bionoff
    bionoff
    56
    Great to hear, be sure to post some pics up for us! If you have any problems, drop me a line, I muddled my way through without too much difficulty and everything still works (so far). :lol:
  18. Bl street
    Bl street
    10
    The indicators and relay were pretty easy only took an hour I think it's because I used all triumph parts so I didn't have to cut any wires they look great I'll put some pics on when I can get the bike out in the light.
  19. sorry im confused :(
    does this mean i can simply buy a LED flash it relay from ebay
    does it matter what one it is as there are universal ones ie ( yammy,suzuki etc ) would they fit on the daytona 675 ?
    i know they moderate the flash times etc and understand they are need to counter the rapid flash of full 4 way LED indicators
    just unsure what one would be needed .. got the all in one led rear light unit and shark fin on the front
  20. eBay item number 281158124932. Use this exact relay, change it for the stock one under left hand fairing. I had one on mine for 12 months with no faults and perfect flash rates, used with stock front indys and an integrated rear light and also with 4 led indicators on my current bike.
