Does anyone know what size the o ring seal on the oil filler cap is? I'm after the inside diameter and cross section sizes. Cheers in anticipation
just been in garage so i took filler off to measure it the 1 on my 2011 daytona is 19.5 mm id and about 2.8mm cross section theres no groove on the casing so you maybe get away with going to a 19mm id and deffinatly 3mm cross section regardless of diamiter the filler cap measures 19.5mm on the out side of the thread and there is 3 mm from the thread to the outside edge of the cap if you cant find 1 ive got a box of assorted o rings ive matched 1 up it will do the job just slightly thinner cross section send me a pm if you want 1 sent
