Race seat, additional subframe?
Discussion in 'Maintenance & Tweaks' started by bradders, Dec 16, 2015.
  1. bradders
    bradders
    19
    started looking at mine, havent ridden yet, track bike. Front seems loose and isnt fixed, should it have a 2nd front subframe (like a box) ? Race seat with foam pad not std seat type
  2. Bigmac
    Bigmac
    5,072
    301
    There are different style of base they secure too, but yes most full seat and tail piece in one have a base underneath the front and the seat secure to that
  3. bradders
    bradders
    19
    I'll throw done up. Guy said it was new body kit do suspect there is a bit missing. Bit annoying!
  4. If it's any consolation the seat Base parts aren't always in the fairing kits. They are usually anot extra as once you have one you can usually use it even after the tail unit has been trashed.
  5. bradders
    bradders
    19
    Where can I get one? Quick google gave no results
  6. Rawhide
    Rawhide
    380
    70
  7. Bigmac
    Bigmac
    5,072
    301
    I've never been quite sure about those ones, how does it go over the seat unit but still mount underneath?? I will find a link for one like mine
  8. Bigmac
    Bigmac
    5,072
    301
  9. bradders
    bradders
    19
    Thx fellas. So if I spin it upside down it should have holes to show how it fixes to the subframe. I had a Minster race seat that had the same set up, but this one doesnt have holes in the seat pad for the bolts, may be that he hasnt simply put them in
  10. Bigmac
    Bigmac
    5,072
    301
    I've had to drill all mine dependant on what base you are using
  11. bradders
    bradders
    19
    Closer inspection the fella had screwed the seat to the subframe, so it was there bit not fixed. Now I see why: why of the bolt fixings is bugerred, so had to drill out the fixings and f'glass the big holes it left so I can fit a new home for the bolt
