Race/track Throttle
Discussion in 'Maintenance & Tweaks' started by moanthebairns, Sep 10, 2014.
  1. moanthebairns
    moanthebairns
    27
    Looking at changing my daytonas throttle as its pretty rubbish around the track.
    I've seen ones with various throttle tubes that are in excess of £100
    whats everyone using?
  2. T_daytona675
    Got a 1050 throttle tube on mine seams to work well
  3. Deegee
    Deegee Moderator Staff Member
    7,934
    Same here, but I know one or two others are using proper QA throttles.
  4. moanthebairns
    moanthebairns
    27
    I just read about that, does it really reduce the turn by up to a 1/4
    I quite like a loose throttle at low speeds but for full throttle its ridiculous on the track
  5. I use a venhill quick action throttle, I really like it on track. Means I can get the throttle wide open much quicker coming out of corners
  6. T_daytona675
    1050 makes big improvement on standard 675 throttle......on the earlier models anyway not sure what newer models are like
  7. Bigmac
    Bigmac
    5,072
    301
    +1 for the venhill QA
  8. Active Q/A it's comes with 3 different throttle tubes
  9. ste m
    ste m
    253
    13
    I'm picking my bike up in two weeks an it has a quick action throttle on it. I really don't want it on there as I'm a new rider an I think it's going to make things worse for me. How easy are they to remove an return to standard?
  10. StMarks
    1,005
    If it is just the popular "1050 throttle tube mod", then you are unlikely to even realise it is on there mate.
    Remember; You have control of the throttle.
    If, as said above it's the std one, then it is very easy indeed to change back.
  11. moanthebairns
    moanthebairns
    27
    is there much difference in the 1050 tube and the standard.
    The only thing that stops me getting a QA throttle for the track is I actually like to have a bit of play in my throttle I don't like just on and off.
    is it worth going down the road of QA or just the 1050
  12. ste m
    ste m
    253
    13
    Sorry to hijack. How would I know which type it is
  13. scaramanga
    200
    the thing is a 1050 throtle tube is cheap if its not what you want it wont be a big loss unlike some full on q/a throttles
    why not try 1 and see
