I keep finding broken bits as I strip my bike down to sort it out after my spill. The latest is the mounts on the air intake where the front sub frame bolts on. So I've just glued them back on and will see if it holds but in taking it all apart there's a sensor that was bolted to one of the snapped mounts so now I've glued the mount back on I can't see how the sensor was bolted. It bolts in between the mounts on the air intake and the front sub frame. Does any one have a photo of that bit or a diagram or something.
The pressure sensor and the tilt switch are both in that area, pics a s good as I can get. The pressure sensor is here: Tilt switch goes on the little banana shaped bracket on the RHS (as you sit on bike)
