does anyone know if the triumph short levers fit all years of daytona? i know the brembros are diffrent
Should be fine mate. Haven't heard of any differences apart from like you say the brembos Sent from my Desire HD using Tapatalk
I got the short levers on my 11 plate daytona. The brake lever has excess free play. cut a 1.5mm disc from the end of a plastic number plate bolt and stick it down the hole the pushrod goes into. make sure you still have some free play! Make sure brakes dont start to bind on getting warm (i.e. master cylinder vent hole not venting)
There should be another collar that goes inside the second hole on the lever with a hole in it for the pushrod buddy. I mounted mine & it had lots of play, once I realised I'd left it out, everything was fine.
