Tyre change equipment?
Discussion in 'General' started by Gremlin, Mar 28, 2022.
  1. Gremlin
    Gremlin
    37
    Hi All,
    Can anyone recommend any quality brands of equipment for changing my own tyres...so levers, bead breakers, rim protectors and wheel balancers etc...?
    Also, is a dedicated bead breaker better than a combined lever/bead breaker such as the Motion Pro tyre lever/bead breaker?
    I've never changed my own tyres before so any tips and advice would be greatly appreciated, even if it's "Don't do it, let a garage do it" :)
    Thx.
  2. D41
    I bought mine off eBay.... Nikko, Neiko....sommit like that. Came with the rim protectors as well, which is something else you'll definitely want to have. And wheel-weights... which I'd recommend you tape over, just to be super-duper safe. Changing the tyres themselves isn't too difficult... getting the front wheel off was a little daunting the first time...the rear isn't too hard, but then you change them more often.
  3. TimC
    TimC
    I’ve got a Max2H setup. It’s nice but at around £400+ it’s not cheap so you have to be changing tyres regularly for it to be of value.
