What's this ?
Discussion in 'Maintenance & Tweaks' started by Scottyjm675, Jun 11, 2017.
  1. Scottyjm675
    Scottyjm675
    Hey guys,
    Does anyone know what this is ?? I dropped the bike and this seems to be the only thing out of place :( and it won't start. 20170611_143249.jpg 20170611_143300.jpg
    1,005
    They look like the relays that are normally mounted below the left hand side panel cover below the fuses & behind the radiator.
    Did you check the plugs on the underside of the instruments yet mate.?
  3. Scottyjm675
    Scottyjm675
    I have everything seems to be plugged in correctly and fuses are in aswell, really stuck to see what is stopping the speedo from coming on.
  4. StephenP
    412
    That's just the indicator relay, it hooks onto the left hand lower bracket, mine is just cable tied into place.
  5. Scottyjm675
    Scottyjm675
  6. StephenP
    412
    Isn't there a tilt sensor? Not tripped that have you?
  7. Scottyjm675
    Scottyjm675
    Will I need to unplug and re plug it in if I have? Bike was dropped :( ever since I turn the ignition the lights come on but not the speedo so bike won't start, Bike is in neutral and stand is up also tried with it down.
  8. Tilt switch is a small plastic box bolted to the side of the air intake, it's bolted on via a small brake next to the clocks, in bolt it and give it a good shake to reset it, they tend to get stuck!
  9. Scottyjm675
    Scottyjm675
    Thank you I'll give that a go on Friday and hopefully the bike comes alive again :)
    • Creative Creative x 1
  10. I know it's a simple one but you haven't just knocked the kill switch on in ur accident have you?. You wouldn't be the first to be baffled by this little switch I always forget, I mean people always forget.
  11. Scottyjm675
    Scottyjm675
    No the kill switch is in the run position hopefully it's the tilt sensor, otherwise I'm stumped
  12. cpszx
    569
    as per other thread, have you also checked clutch switch?
    although if the dash doesnt light up, i thought only kill switch or connector would cause this?
  13. Look like you dropped it on the generator cover?
    Could be the Crank Position Sensor that sits in there with the winding
  14. If you measure the resistance across the white plug that comes out the top of teh genny cover you should have 200ohms
  15. Scottyjm675
    Scottyjm675
    Okay cheers guys, I'll have a look at these too
  16. Scottyjm675
    Scottyjm675
    Hey guys ! It's running again woop woop! However the engine management light is on? Is this because I dropped it ?
  17. The eml might go away after a few heat cycles until the fan kicks in.
    Now will be the best time to get it hooked upto the tune ecu to find out the error codes
